power steering pulley installer..
Old Nov 15, 2005 | 10:11 AM
JordonMusser's Avatar
Default power steering pulley installer..
I am using the Performance Tool unit, and it seems that the larger thread size (the one that tha actual installer is threaded on to) is the part that is threading into the PS shaft, NOT the smaller thread on the end. IT also appears that only the first 2 threads are engauging before it bottoms out, because of the 3/4" or so of smaller thread. and this brings me to my problem, I ripped those 2 threads right off the installer trying to get the pulley on the last 1/8th inch. Does anybody know what thread size the PS shaft is?
thanks!
Old Nov 15, 2005 | 11:06 AM
technical's Avatar
The smaller threads are 20tp and the larger threads are 16tp.
Old Nov 15, 2005 | 03:17 PM
thanks for the reply, do you know the diameters? I assume this is american thread pitch?
I am guessing 1/4-20 on the smaller and 5/16-16 on the bigger then?
Old Nov 15, 2005 | 03:51 PM
technical's Avatar
Yes standard not metric. I'll check the diameter for you.
