I have a CAT in the I-Pipe.
I have Hooker long tubes, going into a mufflex off road y. And In the I-pipe I have 1 cat installed. Now I originally wanted two in the mufflex, but the exhaust shop told me they didnt know if they could fit 2 carsound cats (which I bought previously) into the mufflex without it not being properly sealed. And since it was a nice setup, they didnt want to go messing it up. Well, now that it is messed up, do you think that 1 cat in the I-pipe is restrictive? its 3" in/out as is the y and catback is all 3". But I just wanted to know from the mathmaticians in here, if having that cat in that part of the exhaust would be worse than 2 in the proper spots of the Y.
The only reason I could see is to cut out some rasp, but I would think that an XR1 or a Bullet would be less restrictive and better suited for the job.
it was for the smell.
Use this as a guide, 2.2cfm for every 1hp.
I have no idea what you CAT flows at, but I doubt it's startling. At best it is probably 400cfm, but would well be below 200cfm. If you assume a stock engine produces 345bhp.
345 x 2.2 = 759
Your minimal flow rate on a stock engine should be 759cfm. Even the best metal matrix CATS only flow at around 550cfm so yes it is very restrictive.
If you have one CAT per exhaust/cylinder bank it only has to deal with half the exhaust gas and half the flow rate. So on a stock engine with two CATS they only need to flow 380cfm which is pretty doable my many aftermarket CATS.
345 x 2.2 = 759
Do you think this cat is used up? Or can it be recycled? Remember I have 2 carsounds (1 in garage, 1 in I-pipe). And when I come around to getting someones true dual system, I want to put these in. If I can recycle it I will.
