ls6 intake and knock sensor
Old Nov 18, 2005 | 02:17 PM
The PAT WS6's Avatar
Default ls6 intake and knock sensor
i put on an ls6 intake on monday and got a knock sensor code with the egr and i went to fix the knock sensor wires that were pinched, so i take the intake off and fix the wires, and everything is good i go to start it up and it shoots up to 2000 rpms, i turn it off and examine that my throttle cable could have been a lil tight where it loops around so i adjusted it, and restarted the car and everything is fine,? i pretty sure i didnt brk the oil pressure sending unit but what else could this have been, im just a lil parodnoid,
thanks
Old Nov 18, 2005 | 04:29 PM
1BADTALS1's Avatar
i dont understand what your saying... or what you want you basically said that you swaped the intake mani and had a couple probs but now all is well..
so congrats.. i did mine and broke the oil psi unit... **** happens i guess..now i just got the ses light on again and it said knock sensor 2 low imput.... i think i might have also pinched some wires.. i checked all the harnesses and made sure they were tight one was loose..reset the computer and it has not came back.. yet....
