True Dual install question
Old Nov 23, 2005 | 01:47 PM
akZ28's Avatar
Default True Dual install question
Im going to be installing my true duals tomorrow. I was just wondering how close you can mount the mufflers to the floorboard before they hit. I have poly motor/trans mounts on the way. thanks
Old Nov 23, 2005 | 02:41 PM
DreamState23x's Avatar
I don't think your gonna get the mufflers to touch but the drivers side pipe will if not adjusted right. you will see it takes alot of fiddling. twisting one pipe one way an inch and another a different way will let you raise things up higher. You will se, fiddle fiddle fiddle.
