How to get motor to take water?
The temp gauge on the dashboard is reading around 185-190.
And anyway to get the air bubbles out? Thanks
HTTP://WWW.LS1HOWTO.COM/
block? Unless you took one of the plugs out of the block it
probably didn't.
I flushed my system then kept flushing with distilled water
then made my coolant/distilled water mix based on what
I calculated was still in the block from total system volume.
Might be kind of ****, but I like to be thorough.
I've flushed mine several times, never had to "burp" the
system either, for some reason. Other vehicles I have.
