Should I make more intake changes??
Old Nov 28, 2005 | 09:04 AM
MBC Racing's Avatar
Default Should I make more intake changes??
I have a 383 in my 00 Z28. I mainly autocross and road race the car. The engine was built for a broad power band and a lot of torque. I have a 236/236/111 .550/.550 cam, stock de screaned maf, ported ls6 intake and ported and smoothed stock TB.
The question I have is " Is it worth going to a larger TB, MAF, and or different intake manifold???" If so, how many HP are we talking?
I went with the lift I am running because the car spends a LOT of time between 4500-6800 rpm and I don't want to change valve springs every month. Also, the car puts over 400 ft-lbs to the wheels from 3200-6000 rpm.
Thanks for the info.
Brad
Old Nov 28, 2005 | 09:27 AM
300bhp/ton's Avatar
well you should see more power, but whether it will make any odds to the performance of the car is a totally different matter.
Not doubting your ability, but I seriously doubt your car is as fast as it could be driven. Driver and suspension/drivetrain mods will most likely make the biggest difference. But of course they don't show up on the dyno.
Also loosing some weight off the car should help.
That's how a Lotus Exige 1.8 with 190bhp is quicker than a 400bhp 6.0 Corvette C6 Z51 around a race track.
Old Nov 28, 2005 | 10:34 AM
MBC Racing's Avatar
There is always room for improvement with driving ability.
However, I took 2nd in points for the year and have consistantly had the 2nd fastest time of the day at all the tracks I have raced at this past year. The only car that beat me won the 2003 One lap of America race. It is a C5r powered Z06 with well over $100k in mods. He has huge tires all the way around, a big functional wing like the C5R cars and weighs in a lot less than me. I run in A-Race which is an unlimited class with over 3.0L displacement NA or 2.5 forced induction. The class has a lot of gutted mustangs with over 390 cubes. The 3rd place car is a 93 GT with a 408 and fulley gutted. I have full interior and weigh in at 3800 w/driver. I don't plan to gut my car and enjoy using my AC. There is really no other suspension mods left to do to my car.
I have only been doing this the last couple years so I know there is more time to be shaved off. I used to be a drag racer prior to this. Any more power would be nice as long as it doesn't take away from the low and mid range power.
Brad
Old Nov 28, 2005 | 11:03 AM
300bhp/ton's Avatar
might be worth trying to find some dyno graphs of the 90/90 FAST setup.
I suspect it will move the torque a little higher up the rpm range if I'm honest, although I would expect gains across the entire range. If you've got the dosh I say go for it.
Sounds like a fun race series. Although BIG cubes and BIG tyres don't always win races.
In the late 70's (76+) Bob Tulius was very successful in the SCCA Trans Am Championship. He was running a V12 Jagaur XJS. Keeping the stock 5.3 litres and 500-550bhp he still beat the large 454ci Corvettes which had upto 100bhp more and often weighed less. Tulius was a very good driver, but the handling of the car was probably one of the biggest factors. However the XJS may have been quick, he also prepped a Triumph TR8 for the same series, it only had a 4.0 litre Rover V8 with 360bhp, but due to weighing a fair bit less than the XJS it was faster around every track. It was actually banned from the series as it would have embarressed the large engined cars.
Old Nov 29, 2005 | 07:25 PM
WILWAXU's Avatar
I would look at the TPiS 90mm oval TB mod for the LS6 intake. It seems to provide the best "under the curve" hp & tq numbers and the peak numbers are close to the Fast setup.
