Porting Stock TB
Old Nov 28, 2005 | 08:56 PM
HowellSoccer88's Avatar
Lightbulb Porting Stock TB
Is it something thats easy and I could do on my own or should pay to have it done. Basically, what does it entail?
Old Nov 29, 2005 | 05:08 AM
Bo White's Avatar
Search this, its been thoroughly discussed and the info is here.
Old Nov 29, 2005 | 06:00 PM
radz282003's Avatar
Pull the TB off and start grinding. Be careful not to go too far, and don' t mess with the idle air motor openings. Just get rid of the ridges, and you' ll be good.
Old Dec 2, 2005 | 10:07 PM
WILWAXU's Avatar
Ok, go a little motivated and converted AdamSS's FTP files into a webpage: http://www.geocities.com/wilwaxu/throttlebody.html
Lots of other info out there:
https://ls1tech.com/forums/generation-iii-external-engine/299194-throttle-body-porting-101-a.html
https://ls1tech.com/forums/generation-iii-external-engine/248589-ported-throttle-body-pics.html
http://www.ls1howto.com/index.php?category=3
http://www.cardomain.com/ride/296918/6
http://www.ls1camaro.net/sections.php?op=viewarticle&artid=16
Here's the FTP files I used to build the webpage:
Originally Posted by AdamSS
OK - I found a host. It's not an excellent one, so try not to crash it with 50 simultaneous downloads
Ok - I had to split it into two zipped files. (max upload is 1MB)
http://ourworld.cs.com/mullet2001SS/TB_files_1.zip
http://ourworld.cs.com/mullet2001SS/TB_files_2.zip
What you need to do is to unzip those two into a "TB_files" folder. There should be a TB.html file that should be moved outside the TB_files folder, that activates the page....
So, for example it should look something like this:
c:/TB_files/ (with all unzipped JPG's in it)
c:/TB.html (file that activates the page)
Good Luck....Again, go easy on the host, otherwise it's gonna crash...
Old Dec 3, 2005 | 09:03 AM
AdamSS's Avatar
Thanks for hosting those !
This is a great writeup. I'd sticky it
