What lid/MAF for 90/90 setup? Im starting to gather the parts to switch over to a fast 90/90 setup. I have the intake/ TB/ 90mm power ring covered. what are my options for lid/maf? I currently have a TSP clear lid, stock maf, it seems kinda pointless to switch to a 90/90setup and leave the small lid/maf. what are you guys running? Its a daily driver so i dont want to go with SD, yet anyways. |
TTT! Id like to know also. |
Most people get a 85mm maf and 85mm lid, or you could go SD and just put a K@N on your TB...from what i hear SD is fine for Daily driving. |
what MAF's are alright to use, the granitallie one is untuneable right? Are the SLP ones any better? |
im using the TSP 85mm, and SLP MAF 85mm. if your having the car tuned the SLP is just fine, sean at fastech rocommended the SLP. said dont get the granatelli |
Exscuse me if I'm stupid but what the hell is SD? |
Speed Density tune, where the MAF is not used. |
your mpg will be quite a bit less in SD though it will run fine, acutally better if you have a large cam |
Originally Posted by SUTTERERMAN85 your mpg will be quite a bit less in SD though it will run fine, acutally better if you have a large cam |
Who does this SD tunning? |
yea just use a 85mm lid and maf |
go with the SLP 85mm MAF and a 85mm Lid |
Originally Posted by a98ws6 Who does this SD tunning? |
© 2024 MH Sub I, LLC dba Internet Brands
