ASP Pulley worth it?
Old Dec 5, 2005 | 11:41 PM
BadBowtie03's Avatar
Default ASP Pulley worth it?
Is the ASP pulley worth the money??
Also, is there one or two pullies involved with the upgrade?
I need to get a new surpentine belt right?
Thanks!!!
Old Dec 6, 2005 | 12:27 AM
Bad Blu Formula's Avatar
It is a worthy mod. Probably about 2 tenths in the quarter. Usually people only go with the crank pulley and forget about the alternator pulley. When you order a new pulley it should come with the belts.
Old Dec 6, 2005 | 01:38 AM
do you gain any more power if you get the alternator pulley as well... or is that only to help with power accessories?
Old Dec 6, 2005 | 05:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
With the Alt pulley it just helps more with parasitic loss. I didnt do it due to the fact that I have heard your lights will be dim and other power accesories will seem weaker.
