Do I Need the PCV?
Old Dec 6, 2005 | 03:00 PM
BULLET99Z28's Avatar
Default Do I Need the PCV?
a few minutes ago I was disconnecting the pcv from the manifold, and hose from the valve cover,and I tore the rubber boot that the pcv fits in. Any way i am doing the diy catch can(see Wakerider's post here). any way when everything is hooked up, do I need the pcv any way, since there is a filter on the catch can. my car is a 99Z. oh yeah, whats with the ground strap hooked up to the pcv?thanks for any help.
Old Dec 6, 2005 | 03:26 PM
technical's Avatar
You should keep the valve. Otherwise you'll suck more oil out of the engine.
Old Dec 6, 2005 | 07:21 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
That strap is listed as a heat sink in GM literature. Supposed to warm the valve faster. I don't think it's really necessary though, I removed the strap when I did the verticle PCV mod on my WS6 and saw no ill side effects.
Old Dec 6, 2005 | 11:11 PM
Josh McGrath's Avatar
Hell, I ripped mine to shreds 2 years ago and havent had a problem with it... so no harm no foul
Old Dec 10, 2005 | 07:04 PM
RPM said I do not need the pcv since my catchcan has a filter in it to stop oil flow.
