dont know jack?
Old Dec 8, 2005 | 11:27 PM
drummydummy's Avatar
Default dont know jack?
So, im getting started on my Pacesetter LT's install. I want to do it myself so this might be a stupid question, sorry. Where is a good place to jack the car up from. k-member? subframes? where is a good place to jack it up from while installing the headers where they wont get in the way and what not? thanks guys.
Old Dec 9, 2005 | 06:01 AM
LoudmouthLT1's Avatar
Look behind the front wheel wells, you'll see a thing that kinda looks like a milk crate, behind that is a pirce of "frame" that is what you should jack on and then place jack stands under the lower control arms as far out as you can so the car stays up high enough.
Old Dec 9, 2005 | 08:28 AM
YellowToy/A's Avatar
To put headers in u need to jack the car High. The drivers side loads from the bottom and it has to be on end. do a search. Be carefull.
Old Dec 9, 2005 | 12:39 PM
BlackHawk T/A's Avatar
http://www.installuniversity.com/ins...ift_points.htm
Old Dec 9, 2005 | 08:52 PM
Thanks guys! hope the header install goes well!
Old Dec 9, 2005 | 10:09 PM
BigDaddyBry's Avatar
I drove the rears onto Rhino ramps, jacked up the front, put only the front on jackstands.
