Duals banging floor....affect dyno?
I scheduled my car for the dyno this Wednesday. At partial to WOT, the driver side pipe bangs on the floorboard. I have poly motor mounts on the way. Will this banging have a negative affect on my numbers. I have read that the banging will set off knock sensors or something to that nature. I just want to make sure that this won't cause me lower or inaccurate numbers. If that is the case, I will wait until I get the poly motor mounts in. Thanks for any input.
From: Your girl's back door giving her the long stroke while you're at work
I ended up using a five pound hammer to take care mine hitting the floor. I also had to use some rubber hose, just in case. My problem was with TSP TDs.
Originally Posted by WicketMike
it will probably cause some KR, mine did. i had to put some rubber inbetween so it wouldnt hit
