Will this make my car quieter??
Old Dec 14, 2005 | 12:21 PM
RAMAIR57's Avatar
Default Will this make my car quieter??
I have a wide open Borla right now with slp longtubes and off road y-pipes (aftermarket cam too, pretty big one). The car is simply too loud, and I really have to quiet it down. If I put in the restrictor plate that came with the Borla, will it quiet down, or will that not even matter because I have the offroad pipe instead of the cats? Someone please let me know because I finally found the restrictor plates and Im wondering if I should install one of them
Old Dec 14, 2005 | 01:18 PM
iamsickofitall's Avatar
more restriction = less noise
Old Dec 14, 2005 | 02:14 PM
silver02Z's Avatar
It should be quieter, but will sound different for sure...Put one of the plates in and see...
Old Dec 14, 2005 | 04:19 PM
RAMAIR57's Avatar
will it make a big performance difference if I put the most restrictive plate in? I want it to be alot quieter, but I am just hoping it wont affect performance too much!
Old Dec 14, 2005 | 04:35 PM
spy2520's Avatar
unless you are pushing alot of power i doubt it will make much difference.
Old Dec 14, 2005 | 07:27 PM
BULLET99Z28's Avatar
Default 2 Loud?
check the sig, same as you except for Hookers, its loud at startup, but just normal easy drivin, its barely louder than b4 the headers, no cats here and the borla is wide open as well. gettin on it is a different story, I really like it on the hiway to, just enough tone to let me know she's runnin
Old Dec 14, 2005 | 09:05 PM
RAMAIR57's Avatar
i dont know if it makes a difference, but I have an all bolt on car with heads and a huge cam with a high stall (the rpms are always pretty high, making it even louder). The car is so loud that I always getting pulled over now, and its a pain. Even at idle, its LOUD. I will try to put the plate in and see if it makes a difference, but Im just hoping that putting the most restrictive one in wont hurt my performance too much (I currently have about 400rwhp n/a). Did anyone go from a similar setup and have any numbers on performance afterwards compared to before?
