Codes and O2's
Old Dec 15, 2005 | 08:45 PM
Darksol's Avatar
Default Codes and O2's
I took my car to get it scanned today and it threw out a PO134. So my question is which o2 is it? And isn't there a special tool for removing one or am I on crack? I know the sensors are on the exhuast but which is which? Thanks in advance guys.
Old Dec 15, 2005 | 09:42 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
My book says P0134 = O2 sensor circuit no activity detected, bank 1 sensor 1. That would be the driver's side front (pre cat) O2 sensor. They just come off with a wrench, can't remember the size off hand though. I know I've used a crescent wrench before.
Old Dec 16, 2005 | 08:12 AM
black01_WS6's Avatar
you are right, if you ever have another question about codes the stickeys have all the info you need. it covers all the codes. or put your code in the search and you will find vast amounts of info.
Old Dec 16, 2005 | 10:55 AM
Darksol's Avatar
when i put the code in the search box it came up with other codes as well.
thats how i knew it was the o2 sensors. i try to search before i post. thanks though.
