installing headers
Old Dec 19, 2005 | 11:46 PM
SouthernSilverSpeed's Avatar
Default installing headers
I ordered some headers and I was wondering if I needed to use my factory exhaust manifold gaskets or should my headers have come with some header gaskets?? I know you can buy some "awesome no leak gaskets", but I was just wondering if I need aftermarket gaskets or are the factory ones ok?
The company I bought them from said it would include all NECESSARY gaskets and hardware to install these. since I did not get any header gaskets, then are they not necessary I assume??
Old Dec 19, 2005 | 11:49 PM
Lithium's Avatar
SSU's Drunk Typing Whore
If the gaskets that come with your headers are paper, throw them away. Always use the stock GM gaskets. If the ones you take off the stock manifold look good still use them.
Old Dec 19, 2005 | 11:55 PM
so these $36.99 6 piece gasket set is a waist????
Old Dec 19, 2005 | 11:56 PM
Lithium's Avatar
Not sure...what they made out of?
Old Dec 19, 2005 | 11:57 PM
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
its towards the bottom its called perceys seal 4 good
98 camaro z 28
Last edited by SouthernSilverSpeed; Dec 19, 2005 at 11:58 PM. Reason: for got this
Old Dec 20, 2005 | 12:00 AM
enter in camaro year 98 then click find parts
then cck exhaust and its at the bottom of that.
Old Dec 20, 2005 | 12:02 AM
needless to say I can use factory exhaust manifold gaskets and i do not have to get after market ones
Old Dec 20, 2005 | 12:09 AM
Lithium's Avatar
Yeah a lot of people reuse the stock gaskets.
But those you showed me look pretty damn good to me, it will do just fine.
 Michael S. Palmer
Old Dec 20, 2005 | 12:14 AM
i apreciate all of the help...Now all I have to do is wait for the rear o2 sims and the front o2 extensions and then the hours of cussing then I will be happy. P.S. I just created another thread about the air and egr got any comments??
Old Dec 20, 2005 | 12:18 AM
Lithium's Avatar
Deleting AIR/EGR will set off the SES light. I think the AIR code takes a few days to go off. Either way you have an SES light. There will be no loss in performance etc...just some codes.
You can delete the codes via LS1edit or HPtuners. Or you could just lean to live with them.
Old Dec 20, 2005 | 12:20 AM
Lithium's Avatar
I hear ya with the waiting part. Seems all I have been doing this past month was wait on **** to ship to me. I am expecting some valve covers tommarow so hopefully I recieve those bad boys.
Its a good experiance installing headers. Be prepared for a lot of cussing and blood and beer
Old Dec 20, 2005 | 12:24 AM
but will I gain horse power from taking these out or is it just simply a weight loss??
Old Dec 20, 2005 | 05:19 PM
Lithium's Avatar
No hp to be gained.
It will save some weight, pretty decent amount actually.
It will also clean up the engine bay...making your life a lot easier.
Old Dec 20, 2005 | 08:49 PM
DreamState23x's Avatar
Its a good experiance installing headers. Be prepared for a lot of cussing and blood and beer [/QUOTE]
My headers only took about an hour to install. Now the TD exhaust was another story.
Old Dec 20, 2005 | 08:54 PM
dnm12's Avatar
why were the true duals any issue i am going to have the exact same setup, also what gaskets did you end up using
Old Dec 21, 2005 | 01:20 AM
Juiced2000SS's Avatar
I used those on one set that I installed and those are some damn nice gaskets. I think they call em "dead soft aluminum" and they form a nice seal when tightend down. Stock GM will work but those are nice for the extra $$
Old Dec 21, 2005 | 01:43 AM
I used the gaskets that came with the headers but kept my old one just in case, but have not had a problem.
The duals just took a lot of adjusting over and over again to get them right.
Old Dec 21, 2005 | 08:26 AM
GeorgeR@kooks's Avatar
LS1TECH Sponsor
Talking
just to let everyone know we are now offering a new gasket to replace the old paper. They are a 2000 degre gasket you can hold a lighter to them and it does not effect the gasket at all. They are awsome to say the least. Call 631 586 9002 Ext 308 if you need a set. George R.
Old Dec 21, 2005 | 11:15 AM
ibanez7's Avatar
I just installed HOOKER lts and ORY.
I reused the factory steel gaskets and bolts, also since I went catless I removed the air pump system and bolted block off plates on the AIR extensions off the headers.
oh yeah ratcheting wrenches are you best friends!!!
To save your knuckles on future engine work:
when you remove the passenger side coil pack, you will discover that the rear stud is a bitch to get to and remove. So once the stud and coil pack is removed, trim the rear mounting hole on the coil pack into a "U" shape.
This way you can fasten the stud back into the valve cover and slide the coil pack mounting hole into the stud. Now for furture removal you will only have back the stud off alittle bit or tighten it a little bit.
This is the where I cut my hands up and it really slowed down the process trying to lossen that stud!!!
