exhaust leak???
Old Dec 21, 2005 | 09:33 PM
nokeman's Avatar
Default exhaust leak???
What are the common symtoms of an exhaust leak? I ticking sound comming from where my headers connect to my exhaust. If not a leak, what could this be? Thanks!!
Justin
Old Dec 21, 2005 | 09:42 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Just feel around with your hand you should feel the leak.
Old Dec 22, 2005 | 12:10 AM
nokeman's Avatar
oh ok. do you know what this ticking could be?
Old Dec 22, 2005 | 12:31 AM
Lithium's Avatar
Could be anything I guess. I have always had a ticking sound from around there myself. So I am not sure if its normal...
Old Dec 22, 2005 | 02:45 AM
bww3588's Avatar
EGR vavle. when the gaskets on that go bad or somewhere on the right side of the engine the EGR will start ticking. my guess is youll get a code saying EGR circut low.
Old Dec 22, 2005 | 10:30 AM
nokeman's Avatar
well the ticking isnt comming from the engine bay neccessarily. i almost cant hear it when im standing in front of my car looking into the engine. but when i am sitting in the car with the windows down or outside the car, and especially under the car, i can hear it comming directly from where my collectors meet the exhaust.
Old Dec 22, 2005 | 10:39 AM
bitchncamaro's Avatar
I am haveing the same problem ..... Ive checked for leaks ,and retighten all bolts.Only leak i have is a small one at the Y/I pipe.(no biggE)... The tick on pass.side went a way after i found 1 spark plug little lose.But no luck on the driver side...I can only hear it when iam under the car or at the drive thou with the sound bounce N off the wall,,,,ITS DRIVEN ME NUTS.....
Old Dec 22, 2005 | 11:38 AM
01formula6's Avatar
I have the same exact problem. I still haven't had any luck figuring it out.
Old Dec 22, 2005 | 11:40 AM
bww3588's Avatar
youll hear it all over the car. i drove a 98 yesterday with the EGR problem and the guy told me it was an exhaust leak and the SES lights was on. i put the scanner on and it showed up EGR circut low. so its the EGR vavle going bad. i could hear this under the hood, under the car, behind the car, in the car with the windows up, crusing down the road at 70 mph. so i would check into it if i were you. it would be cheaper.....or never mind since you have an 01. but bitchincamaro i would check into this. nokeman sounds like you got a header gasket blown out or maby a rocker loose.
Old Dec 22, 2005 | 03:33 PM
Ill look in to it , no ses but ill autotap it see if i can see whats up.... but under the hood no tick,,, comes and goes
Old Dec 22, 2005 | 09:49 PM
bww3588's Avatar
sounds good. good luck
Old Dec 22, 2005 | 09:53 PM
nokeman's Avatar
is it expensive to fix a header gasket or a loose rocker? i hope its nothing as major as a loose rocker. i did just change my spark plugs so could it be that one is loose?
