should this worry me?
Old Dec 24, 2005 | 09:06 PM
bolton98TA's Avatar
Default should this worry me?
my car had a problem with the dipstick working/poping its way up about 1/4 inch. after i push it back down it will do the same thing in a view days. i replaces the whole pcv system, pipes and all and it still does it.
does anyone else have this problem?
what could be causing it?
thanks, ryan
Old Dec 24, 2005 | 09:09 PM
Lithium's Avatar
SSU's Drunk Typing Whore
you sure you put back in right after you installed the LT's?
I am not sure man, scotch tape?
Old Dec 24, 2005 | 09:10 PM
KY Z28's Avatar
that is an odd problem, but this could be caused by excessive crankcase pressure. that is generally caused by excessive ring blow-by. not good man...
that is totally a guess though
Old Dec 24, 2005 | 09:31 PM
bolton98TA's Avatar
blow by would lower my HP # a good bit tho wouldent it? it has done this ever since i got the car. could the pcv pipes be stoped up where they come out of the valve covers? i want to do a compression test but its going to be a pain in the ***. the car has 80k miles on it and has had frequent oil changes so i wouldent think the rings were worn bad.
the thing that makes me wonder about the blowby is it only seems to do it when if feels like it. i could drive it one day and it would be fine, and another day it will work its way out. would doing a compression test on one cylinder tell me anything?
Old Dec 24, 2005 | 10:21 PM
Juiced2000SS's Avatar
Try the GM vented Oil Filler Cap and see if that helps. I forget the part number but if you do a search you'll find it.
Old Dec 25, 2005 | 03:30 PM
bolton98TA's Avatar
thanks man, i was thinkin og doing something like that but nuthing poped in my head. thanks for the idea!
Old Dec 26, 2005 | 02:00 PM
02NHRA's Avatar
You could even just pop a breather in the hole if that gm cap is too pricey
