? using 6.0 manifold
Old Dec 28, 2005 | 03:05 PM
jdeuel87's Avatar
Default ? using 6.0 manifold
I have a LS1 long block [2000 Camaro] and am considering using 6.0 manifold/fuel rails, and then adding LS2 throttle body [will have wiring harness made from Speartech for hybrid build...Can I bolt this up to my existing long block? Any pro's or cons with this set-up?...Thanks, John
Old Dec 28, 2005 | 05:44 PM
WILWAXU's Avatar
Should work. As long as it's not going in a late model camaro or firebird. That intake will cause clearence issue with the cowl.
BTW, if you haven't checked it out yet, we have a Conversions & Hybrid section for LSx motor transplants.
