Ssra???
Old Dec 28, 2005 | 06:09 PM
Andrew_071's Avatar
Default Ssra???
OK my Camaro has a Loudmouth exhaust system, an airlid, K&N air filter, Ls1 Edit, 3.73 gears, 160 thermostat. Anyone know about how much power I can expect if I install a SSRA kit?
Old Dec 28, 2005 | 07:27 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
+1 mph trap in the 1/4.
Old Dec 28, 2005 | 07:29 PM
Lithium's Avatar
SSU's Drunk Typing Whore
gains of 15rwhp at speeds above 60mph.
Old Dec 28, 2005 | 07:42 PM
Andrew_071's Avatar
Thanks for the info, that 15 RWHP comment has made up my mind, I'm buyin' it tonight.
Old Dec 28, 2005 | 07:43 PM
Andrew_071's Avatar
Oh yeah. Anyone know what website sells the SSRA for the lowest price?
Old Dec 28, 2005 | 07:46 PM
!LS1 11 Second Club
If that were true, everyone would have one.
I had one. 117 vs. 118mph on my cam only setup. About as good as a little tailwind. It's a little on the voodoo side of things, but eh, what the heck, every little thing helps I guess.
Old Dec 28, 2005 | 07:48 PM
Andrew_071's Avatar
Hmm. how much RWHP would you say it gave to you?
!LS1 11 Second Club
After I posted this, the manufacturer included longer screws in the kit. Hehehehe....
 Michael S. Palmer
Old Dec 28, 2005 | 07:49 PM
Andrew_071's Avatar
What are the longer screws for?
!LS1 11 Second Club
Being that a chasis dyno is stationary, who knows?
Old Dec 28, 2005 | 07:50 PM
!LS1 11 Second Club
To make sure it doesn't fall off when you drop clutch @ 5000 rpm.
Old Dec 28, 2005 | 07:52 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
It is a very worthwhile mod IMO. The HP gains won't show on a dyno, but it is worth at least a tenth in the 1/4 and a bit more in better air.
If you are going from no air induction modification to a SSRA, you will be very pleased.
I got one of the early versions that were made of brittle Polyethylene and not real durable, but it is currently in use (pieced together after many repairs) and is serving a good purpose. The metal version would be your best bet.
Good luck!!
Old Dec 28, 2005 | 07:53 PM
!LS1 11 Second Club
I put it back on the car, until I ripped off the front portion again on a parking curb. After that, I used nuts and bolts and a ton of black masking tape. Worked like a charm.
Would I buy another? Maybe.
Old Dec 28, 2005 | 07:55 PM
!LS1 11 Second Club
Good luck!!
See pic above.
Old Dec 28, 2005 | 07:56 PM
Andrew_071's Avatar
Ah ok. Thanks a lot for the info guys. It should be a decent mod for my car cause the only induction I have is from the SS hood and we all know how great that works.
Lithium's Avatar
So 10 to 15hp is not true then? 60mph and above??
Old Dec 28, 2005 | 07:59 PM
!LS1 11 Second Club
I don't know. Sounds like a very specific claim.
Maybe?
Old Dec 28, 2005 | 08:34 PM
Andrew_071's Avatar
I had the free-mod before but it pulled too much dirt into the filter so i had to close it up, but when I had it it made a difference I could actually feel, so 10-15 HP sounds pretty reasonable to me.
Old Dec 28, 2005 | 09:45 PM
TXCAMSS's Avatar
If dirt in the air filter is a concern, skip the SSRA. If you want to squeeze every ounce of HP from your car (as most here do) then the SSRA is proven. The 10-15 rwhp is evident in track ETs, but not on a dyno. It is worth the $$$ IMHO.
Old Dec 28, 2005 | 11:04 PM
Roarin_8's Avatar
Went from 106 to 111.7 at the track with a stall and the ssra. I know that the stall didn't give me the full 5mph gain.
