quick question on long tubes?
Old Dec 29, 2005 | 02:23 PM
TAwhore's Avatar
Default quick question on long tubes?
i heard a rumor that if you install long tubes, that it will kill your MPG?
has anyone on here experanced that?
dave
Old Dec 29, 2005 | 02:28 PM
LS69TA's Avatar
I can't see them making you loose mpg, as long as you keep driving the same way. It'd probably go down only b/c you like hearing the exhaust and you stay in the throttle longer.
Old Dec 29, 2005 | 02:32 PM
BackinBlack02SS's Avatar
If you get a tune, the car should actually get better mpg because it's more efficient.
Old Dec 29, 2005 | 03:35 PM
Stoichiometric's Avatar
I would agree, you should get better mpg. When I installed shorties on my 2000 ECSB I noticed an increase in MPG.
Old Dec 29, 2005 | 04:36 PM
12secSS's Avatar
dave
Absolutely false! With headers, a good flowing exhaust, and good flowing intake ... your MPG will increase. This is a fact!
FUN LS1's Avatar
Should be better gas mileage, but I only noticed more power and sound... Didn't see gas mileage drop, either
Old Dec 29, 2005 | 04:59 PM
bitchncamaro's Avatar
Like already said, with a good tune get better MPG (only if you keep your foot out of it)
Old Dec 29, 2005 | 05:47 PM
TAwhore's Avatar
good to hear, i kinda thought that was a false thing about the long tubes, thanks a bunch
 Michael S. Palmer
Old Dec 29, 2005 | 05:54 PM
mpe488's Avatar
Pretty much any breathing mods (bar blowers... duh) will increase gas mileage because your engine doesn't have to work so hard to get rid of exhaust gases. U/d pullies, electric water pumps, and other stuff like that will also slightly increase mileage.
power adders, cams, gears, and torque converters will all hurt mileage, some more than others.
Old Dec 29, 2005 | 06:23 PM
BriancWS6's Avatar
Very well put
Old Dec 29, 2005 | 09:22 PM
camaros4ever's Avatar
I have some pacesetter LTs/y pipe, no cats and a single chamber flowmaster and it gets better MPG than stock.
Old Dec 29, 2005 | 09:32 PM
CBX's Avatar
CBX
My mileage got a little better.
Old Dec 31, 2005 | 11:29 AM
Louie83's Avatar
You are still using the same amount of gas and getting more power out of using that gas. So your vehicle will be covering more distance (miles) but not increasing the amount of gas used to do this (gallons).
Therefore, your mpg increases.
Old Dec 31, 2005 | 11:34 AM
mpe488's Avatar
^thats another good way to look at it.. you can either go farther with the same amount of gas, or use less gas to go the same distance.
Old Dec 31, 2005 | 01:57 PM
LiquidFire350's Avatar
what, am i the only one that lose MPG, i went from about 18-20 down to about 15mpg
then again im untuned and find myself flooring it more often, it just sounds sooooo nice
Old Dec 31, 2005 | 02:04 PM
SSDude's Avatar
Ditto. Better MPG based on volumetric efficiency.
Old Dec 31, 2005 | 02:10 PM
WhiteRhino's Avatar
The majority of people lose mpg because they cant keep their foot out of it after adding performance mods.
Old Dec 31, 2005 | 03:32 PM
davered00ss's Avatar
Moderator
My gas milage went pu 1-2 mpg with Kooks longtubes.
