Plugs and wires
Old Dec 31, 2005 | 11:51 AM
Andrew_071's Avatar
Default Plugs and wires
I have a 2001 SS Camaro that hasn't had a plug change since it was made, do you guys think it might be a good time for a plug and wire change or no? And if so then where is the cheapest site i could order them off of.
Old Dec 31, 2005 | 11:52 AM
EDS01SS's Avatar
how many miles on the car?
Old Dec 31, 2005 | 11:56 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Probably a good idea to change the plugs. I'd recommend some NGK TR55s. Some of the sponsors to the right sell them, they are not expensive.
I'd leave the wires alone unless you have a lot of miles. The stock wires are fine and there is really nothing to be gained by swapping them unless the factory ones are worn/damaged.
Old Dec 31, 2005 | 11:58 AM
Andrew_071's Avatar
I have some good MSD wires cause I had a motor rebuild about 50k miles ago, but there is a total of 80k miles on the car.
Old Dec 31, 2005 | 12:03 PM
RPM WS6's Avatar
With 80K on one set of plugs, I'd say it's definitaly time for a plug change.
Question, if you changed the wires when the motor was rebuilt (at 50K), why not change the plugs at the same time?
Old Dec 31, 2005 | 12:06 PM
2001NBMZ28's Avatar
I changed my plugs and wires at 17K, had densos which didn't look bad - got some TR55's and new wires so I wouldn't have to mess with the heat shields again.
Old Dec 31, 2005 | 12:40 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Plug wires are fine.
Get some TR55's.
