Those with the SLP TCS Logic Module -> IN
Old Jan 1, 2006 | 12:38 PM
JoeyAnderson's Avatar
Exclamation Those with the SLP TCS Logic Module -> IN
I'm thinking of buying the SLP TCS Logic Module, and my current understanding is that it turns the Traction Control OFF at startup. To quote their website:
It's "off" until you turn it "on" with a manual switch on your car's dash or console.
I don't want another switch. Can I use the same factory "ASR" button on my Camaro's dash to turn it on?
Thanks in advance!
Old Jan 1, 2006 | 01:00 PM
joshp14's Avatar
It doesnt give you a new switch, it uses your old one....it just turns it off on startup and if you want it on, just push the factory ASR/TCS switch on your dash.
Old Jan 1, 2006 | 01:10 PM
Hooper's Avatar
See my write up here.
Old Jan 1, 2006 | 01:22 PM
Awesome. Thanks guys.
Forgot to turn it off one night at the strip and stalled a burnout attempt.
I'm willing to spend a little $$ to make sure that doesn't happen again.
Old Jan 1, 2006 | 03:10 PM
SLPSS01's Avatar
LOL that's why I got one. That used to happen to me all the time. The only time I'd never forget is pulling out of the garage, first thing I'd do when I get in the car is turn it off.
As mentioned above, you pull off the plastic cover or plate, whatever you want to call it, with the TCS switch on it and the module plugs into the harness behind there. Takes all of 5 minutes to install and program.
