Clearance with tsp true duals???
Old Jan 3, 2006 | 07:35 AM
1nastyss's Avatar
Default Clearance with tsp true duals???
How is the clearance with the tsp true dual setup, is there a big difference from running 3in. or 2.5in. pipe? Let me know guys....thanx
Old Jan 3, 2006 | 06:00 PM
Lithium's Avatar
SSU's Drunk Typing Whore
You lowered?
If so you could and most likely (depending on the drop) will run into clearance problems.
If not, you will be more than fine.
With a H/C setup you want a 3" system.
