FAST questions
Old Jan 5, 2006 | 09:28 PM
Z'mnypit's Avatar
Default FAST questions
What are yall doing for the MAP sensor on the FAST 90mm intake, are you glueing them or what? I dont like knowing its can move around. Also on the small vacuum line, did you shorten it or just move it around a bit?
Old Jan 5, 2006 | 09:45 PM
CRL 01 SS's Avatar
Didn't really shorten it, but I removed the part of the small vacuum line that T's off. The MAP sensor moved around a little bit, but I didn't glue it to the FAST. It was secure enough, and I don't think it's going anywhere.
Old Jan 5, 2006 | 10:46 PM
SUX2BU's Avatar
As long as your not running boost theres no reason to mess with the MAP sensor. the motors vacum holds it in just fine.
