dirty MAF = running to lean?
Yes it is possible. Did you recently install or clean a K&N filter?
I "fixed" a few LS1 cars that had a dirty MAF. It would knock/ping at WOT, cleaned MAF and the problem went away.
i have done it this way many times and have never had any problems. The higher % of alcohol makes it evaporate almost instantly
you have no idea how much simpler the tuning will be (if you're using maf of course) once you have a clean signal.
