difference between 98-02 throttle body?
Old Jan 9, 2006 | 09:09 AM
01ls1lover's Avatar
Default difference between 98-02 throttle body?
is there any difference whatsoever from a stock 98-02 throttle body?
Old Jan 9, 2006 | 09:25 AM
01 Red WS6's Avatar
I think it's just the cam where the cable hooks up. One is smaller.
Old Jan 9, 2006 | 09:30 AM
01ls1lover's Avatar
so what years fit fine on an 01?
Old Jan 9, 2006 | 11:52 AM
moeZ28's Avatar
1) smaller cam where cable hooks on older throttle bodies allows it to open faster
2) the casting is a little different and the newer ones look slightly different
any year throttle body will work with any year car though, it doesnt matter. my car is a 98 and i have a 2001 throttle body on it.
Old Jan 9, 2006 | 04:33 PM
Rothman's Avatar
I recently read a post where someone was trying to swap a 98 tb to a newer car and had to modify it to work.
Old Jan 9, 2006 | 07:52 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The hard coolant pipe coming off the TB on the passenger side is different on the older TBs as well.
Old Jan 10, 2006 | 11:40 AM
01 Red WS6's Avatar
the coolant pipe isn't an issue though. The bend is just a little different.
I think 98-99s had a smaller cams and using a the bigger cam TB on an older car will cause the butterfly to be open even when the throttle isn't be touched.
But you can swap out the cams and the shaft and use any year TB you want
So anything from an 00-02 will work on your car without modding.
