Valve Cover Differences
Old Jan 12, 2006 | 08:12 PM
skonka's Avatar
Default Valve Cover Differences
Guys,
I cracked a valve cover on my '99 LS-1 motor. I found a set of '99 5.3 Silverado valve covers, cheap. Will these swap out? If not, what would I have to change? Coil bracket mounts? I'm not too concerned if there are PCV piping difference as I've already done the new PCV system.
TIA,
S
Old Jan 12, 2006 | 08:32 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I am 85% sure you are good to go.
Old Jan 12, 2006 | 08:37 PM
Brandon Boomhauer's Avatar
they should mount right up no problems.
Old Jan 12, 2006 | 10:38 PM
SUX2BU's Avatar
The truck PCV has one less nipple on the drivers side valve cover.
Old Jan 13, 2006 | 07:13 AM
skonka's Avatar
Thanks guys. No worries....
Old Jan 13, 2006 | 07:08 PM
WILWAXU's Avatar
yup, the truck stuff PCV is simular to the vettes. If PCV isn't an issue, any 99 & cover will get the job done.
Wouldn't that be passengers side?
Old Jan 13, 2006 | 07:56 PM
SUX2BU's Avatar
You is correct sir!
