Over The Axle TD ?
Does it matter where the pipes go. My logic tells me this will flow better than running pipe over the pass side and swinging the driver side back? Am I thinking correct?
Thanx in advance.
Most guys buy an aftermarket upper PHR and run them both over the passenger side. Check out some of the cars with over the axle true duals, you'll see it. If he has a pipe running over the driverside, even the new upper PHR probably wont work.
