modifying/custom ORY
Old Jan 14, 2006 | 07:47 AM
SOM98TA's Avatar
Default modifying/custom ORY
I'm buying a set of mac mids w/o the ORY..
could I buy a ORY for longtubes and modify it? or would that be too costly?
does anybody sell a ORY for the mac mids?
mac does.. but they want 200$ for it..
anybody do a custom Y pipe?
Old Jan 14, 2006 | 07:56 AM
99Hawk262's Avatar
A good exhaust shop could do it for you. If you go that route, I'd buy a Flowmaster Y-piece and give it to the exhaust shop to use. Awesome piece that will give you better scavenging than just simply throwing two pipes together in a homemade Y. If you go to Flowmaster's website, you'll see it listed with their other accessories, like the H-pipe kit. Or you could use any ORY and have a shop make it fit. It is possible, it would just take some cutting and manipulating.
Old Jan 14, 2006 | 08:31 AM
SOM98TA's Avatar
hm.. flowmaster merge collector?
its only 2.5 though..
Old Jan 14, 2006 | 10:36 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
They have several, ranging from 2.5" to 4" diameters.
Old Jan 14, 2006 | 11:44 AM
99Hawk262's Avatar
Yeah, that's the one. Excellent piece and great power production if fabbed up right.
Old Jan 14, 2006 | 11:59 AM
!LS1 11 Second Club
http://www.jegs.com/webapp/wcs/store...1535&langId=-1
Old Jan 14, 2006 | 01:20 PM
SOM98TA's Avatar
alright I bought a flowmaster merge collector..
2.5 to a 3inch outlet..
and I bought a dynomax bullet 3in/3out..
I'm gona run the y to the merge collector and then after the merge collector run a bullet a foot or so after.. then after the bullet run about a foot of 3inch piping.. I'm not gona dump it.. it typicaly sounds worse dumped.. IMO
how do you think this will work out? sound/power?
Old Jan 14, 2006 | 01:57 PM
!LS1 11 Second Club
looks good. dump it with a turn down angled 45 degrees.
 Michael S. Palmer
Old Jan 14, 2006 | 07:24 PM
Louie83's Avatar
How well would a 4" tuck if you put 2 random tech cats on it? Would it scrape like hell on a lowered car?
Old Jan 14, 2006 | 07:42 PM
!LS1 11 Second Club
The 3" to 4" Y-merge is the one used in the Mufflex/QTP Y-pipe offerings. That Y-merge is huge. Flows extremely well and scavenges, yet good coordination is necessary to avoid tunnel brace conflicts (a problem if you're using a tunnel brace mounted TQ Arm or DS safety loop). The merge goes on at a point where clearance is already not as crucial as, say where the two legs of the Y pipe are located.
Old Jan 14, 2006 | 09:05 PM
Louie83's Avatar
That's good, I'm planning on going QTP HVMC and 4" merge collector y with 2 cats. Should flow well and fit well from what I've read. Now I've just been trying to figure out how much I will be able to lower the car with this set-up.
Old Jan 14, 2006 | 10:20 PM
!LS1 11 Second Club
Lowering the car makes for a tight fit. If it's a cutom job, at least you'll have the liberty of fabricating the setup with strict tolerances.
Old Jan 16, 2006 | 09:07 AM
SOM98TA's Avatar
eh Just gona buy the MAC ORY throw on the merge collector and then the bullet..
let you guys know how it works out.. should make decent power though IMO
Old Jan 18, 2006 | 10:05 PM
Photochop's Avatar
Not to ***** the thread, but would this dual 3" in/single 4" out flowmaster y-merge mate up to a hooker coated y-pipe very well if I was to try and swap out that junction? It looks like the drivers side is bent in at an angle not straight ahead there like the flowmaster looks.
I found a dr. gas y-merge that looks like it would work better (has a bend in it for the drivers side coming in at that angle), but its more than twice as much as the flowmaster.
