Rattling from y pipe (drivers side)
Old Jan 14, 2006 | 10:39 PM
FireBreathingChicken's Avatar
Default Rattling from y pipe (drivers side)
I have the pace setter LT headers and tsp y pipe. There is an annoying and obnoxious banging noise coming from the drivers side. It occurs during certain rpm ranges. Iv'e located where it is coming from, but how should i go about fixing it???? It is the y pipe on the drivers side. I was figuring i could wedge something in there or something that can resist high temps. ANY SUGGESTIONS???? THANKS
Old Jan 14, 2006 | 11:09 PM
GTObsessor's Avatar
Your options are to either pinch the piping (find a clap that'll do it... air hammer will work too), knotch the frame there (nice 10lb hammer works there too), get a new Y pipe, or get some Poly motor mounts...
Old Jan 14, 2006 | 11:13 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have seen people put some heavy duty rubber that wont melt in that spot. I know that it is a real PITA to get corrected in some cases.
Old Jan 14, 2006 | 11:17 PM
GTObsessor's Avatar
if it's at all serious, your pipes are gonna eventually crack. you're letting the piping bend at the mercy of your 300+ ftlbs of torque motor... guess what's gonna eventually give in... the pipes or the motor?
Old Jan 14, 2006 | 11:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You might be able to pull a hanger down as well. Yeah the rubber idea is not the best in the book that is for sure. I was just tossing out another alternative. But you pretty much hit most of the better options.
Old Jan 14, 2006 | 11:38 PM
GTObsessor's Avatar
Poly motor mounts FTW! Make the car feel so much sportier and all the drive train slack is picked up... much nicer
