alternator swap info
Old Jan 16, 2006 | 11:56 AM
skippytheloon's Avatar
Default alternator swap info
swapping for a 165 rated alternator when it comes in, anything special I should know about the swap on tha LS1. Or just loosen the tensioner, unbolt and replace.
Old Jan 16, 2006 | 12:00 PM
black01_WS6's Avatar
its pretty easy as long as you have enough space under your car to work with. I had to undue one side of my front sway bar to get it out and the new one in. while I was at it I just took it off. its pretty simple if you know what you are doing.
Old Jan 16, 2006 | 12:07 PM
trigger1's Avatar
Make sure to undo the connector ontop of the alt.
Old Jan 16, 2006 | 12:22 PM
great, thanks!
