View Poll Results: true duals or catback?
true duals
58
72.50%
ORY and a catback
22
27.50%
Voters: 80. You may not vote on this poll
Old Jan 22, 2006 | 07:58 PM
Redneck Z's Avatar
Originally Posted by SouthFL.02.SS
But, one could also make a 3" (Y) to 4" (I) using the Mufflex Y and Mufflex catback combo. All the while, using the scavenging qualities of the Flowmaster 3" to 4" merge collector of the Mufflwx Y.
Yeah, but not only will your clearance trouble become closer to a TD setup, but you still won't be able to compete with TD's. A good TD setup will always make more under the curve power, and slightly more peak power than a good y setup. That's just physics. An X pipe will also scavenge better than and H pipe or a flowmaster y. A 4" I pipe will flow more than the 3", but with less velocity. Personally i'm sticking with my y-pipe, but I can't deny that a well built dual setup will make more power and maintain higher velocity.
Old Jan 22, 2006 | 08:24 PM
Full-Force's Avatar
Redneck, do you even know what scavenging is? Reason I ask is because all this talk about physics sounds crazy to me.
You ever noticed that an aftermarket race exhaust for a bike will convert a bike that came with dual pipes to a single? There is a reason.
As long as the total area size of the pipes is the same between a dual and y pipe setup there is no reason the dual should make more power. Now that is closer to physics.
Old Jan 22, 2006 | 08:27 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I had a QTP Dual cutout ORY (not known for good clearance) and it still had better clearance whan my ol' TD's.
I'm just arguing that a good Y setup will make tons of power.
Old Jan 22, 2006 | 08:42 PM
Redneck Z's Avatar
Yeah I know what scavenging is, thanks. If you have 2 smaller pipes that have equal area to one larger pipe, then you will have higher velocity and better power under the curve with the 2 smaller pipes. This is a simple concept. I don't car what was done on an aftermarket race bike, and it doesn't matter that so and so made great power with a y-pipe setup. When you are racing and spending all of your time over 5500 who cares about power under the curve? In certain situations a y-pipe works great. I'm not arguing that. All I have been saying is that given equal area, two pipes will flow that same air at a higher velocity and that's why people notice more under the curve power when switching to a dual setup.
Old Jan 23, 2006 | 05:13 PM
300bhp/ton's Avatar
Originally Posted by Redneck Z
A good dual setup will always make more power than a good y setup.
Totally wrong and bad info to give.
Scavenging aside, duals will make more power because (2) 2.5" pipes will flow more air and at a higher velocity than (1) 3" pipe. Most of the duals gains over a well built single exhaust will be under the curve.
Wrong, remember a single pipe has twice the amount of gas flowing thru it, 8 cylinders as opposed to 4 cylinders for a dual setup.
Still wrong, unless running high bhp. a 3.5" Y setup will flow very similar cfm as a 2.5" dual setup can.
Please STOP making things up - you have no idea!!!!!
NO no no no no. An X scavenge's very similar to a Y and differently to a H not necessarily better.
Yes but the aim is to have a setup which flow sufficently for the desired bhp level and does not exceed it.
Really!!!!
Once again 8 cylinders compared to 4. A 3" Y setup will probably have a higher velocity than a 2.5" dual setup because it actually has a lower flow rate.
O This is a simple concept.
Strange then how you seem to have little clue about it
Lots of people it's called physics.
Spot on. Many racing cars (GT, circuit, rally) that use a V engine run a Y setup. LG, the guys who make arguably the best aftermarkey headers for Corvettes. Their own race cars run a midified version of their own LT's and mid pipe - guess what they convert the off the shlef X to a Y pipe.
I guess they should go speak to Redneck and get some advice because their championship winning setups don't comply with physics.
Old Jan 23, 2006 | 05:36 PM
Redneck Z's Avatar
Really!!!!
Your such a goof! Your posts are not only annoying, but untrue. Please apply your misconstrued book knowledge elsewhere.
Old Jan 23, 2006 | 08:08 PM
Reject's Avatar
well he is from england....english men are always right!!
Old Jan 23, 2006 | 09:40 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
haha?
Old Jan 24, 2006 | 12:24 AM
SSRZ28's Avatar
stock vs whisper lid, TD, and LTs
Old Jan 24, 2006 | 04:43 AM
300bhp/ton's Avatar
Hardly, but all the info is in the stickies on this site, plus a lot of other good info if people care to look. If anyone is in doubt try looking for info from David Vizard (he has several books in publication).
Plus it all makes logical sense too. It just some people get caught in to the believe that because one or two people have gone from an AVERAGE Y setup to a GOOD dual setup and seen gains it must be because duals are superior. But that's doesn't makes sense IMO and is just an inaccurate conclusion.
Old Jan 29, 2006 | 11:19 AM
WILWAXU's Avatar
For the record, my 10 second Naturally Aspirated 346 runs 10's through a catback.
With that said, If you have to resort to to personal attacks, you've already lost the arguement
Now for the Moderating part:
Take this as the first warning.
Personal attacks will not be tollerated here.
If you can't keep your posts to techinical information and resort to calling names, etc, you need to find another place to post.
Old Feb 3, 2006 | 10:58 AM
  #32
Rescue Ranger's Avatar
Originally Posted by 91s10LS1
My Friend Has A Stroker Built By Fbody Motorsports In Charlote And They Recomended True Duals So He Got Tsp Dual Kit
Tsp-texas Speed And Preformance U Can Find Them On The Left
You mean your other left?
I had to sit and think about this for a while. I ultimately went with ORY/Catback because:
1. Clearence issues (its not my daily driver, but I live in very hilly areas)
2. Tips look damn cool
3. I don't want the fumes coming up into my car making me stink, I want the fumes coming out the back of the car making the people behind me stink
Either way, that was just my decision/opinion.
Old Feb 3, 2006 | 02:55 PM
  #33
SSRZ28's Avatar
I Think your number 2 and 3 reasons are not valid since i have tips on mine and that takes care of those reasons
Old Feb 3, 2006 | 04:52 PM
  #34
02SS:ZEUS's Avatar
I have got a custom 2.5" TD system with dynomax bullet mufflers and it sounds great. I didn't really feel any difference with power because it got opened up so much, but this exhaust system will be sufficient for about as much power as I can get it. With you already having a stroker, you will more than likely get more power out of it than I did, but if you plan on doing more work and more power, TD's is definately the way to go.
