slp bellow is trash
Old Jan 20, 2006 | 09:31 AM
blazinws6kush's Avatar
I trimmed mine too! Took forever to adjust it how i wanted it!
Old Jan 20, 2006 | 11:26 AM
TARZAN's Avatar
I've got a TPS lid, and had to trim mine up...
-Will
Old Jan 20, 2006 | 05:31 PM
Bird-Of-Prey's Avatar
Originally Posted by blkbird
I will try to get some pics so that you all can see what I am talking about. Both lips just meet together and dont slide in to each other. I have to use a rubber coupling to make them fit together. I am going to work on it tomorrow and will post the results. Wish me luck. Hopefully I wont f*&k anything up.....
Are you running the stock MAF? I'm using a Z06 85mm MAF and I have to do the same thing. The lid and MAF are the same exact size both inner and outer. I have used an SLP, and both an MTI black and clear lid. Same thing on all of these. I actually like the fact that it is the exact same size as the most airflow possible.
Old Jan 20, 2006 | 05:59 PM
OnewayDave's Avatar
I have the SLP it went right on the Blackwing box and stock MAF.
Old Jan 20, 2006 | 09:49 PM
67SS&99SS's Avatar
I have the slp lid and and bellow and have never had a minutes problem with it. It fits great. No trimming at all.
Old Jan 20, 2006 | 10:01 PM
WsSickLs6's Avatar
i had the same problem with the clips falling off all the time, then i removed the tray that resides in the bottom of the airbox...works great now
Old Jan 21, 2006 | 01:55 AM
TheBlurLS1's Avatar
That's what she said...
Except now your lid isnt sealing on your filter right, and you are probably getting some unfiltered air sucked in. 99% of the time that people's clips pop off its because they dont have the front lip of the airlid tucked inside the lower airbox like it is supossed to be.
Old Jan 22, 2006 | 04:59 PM
blkbird's Avatar
Yeah, its the stock MAF. What I did was file down the lip of the MAF and acutally heat up the lid a little to get it flexible enough to push in the MAF. I got it done this weekend. Ran it hard a bit to see if anything would pop out and it didnt. Problem solved.
Old Jan 22, 2006 | 08:34 PM
AKRA's Avatar
I have the SLP bellows, Whisper Lid, Whisper MAF Ends, and the Accufab TB. No trimming was required. fits great.
Old Jan 22, 2006 | 11:32 PM
cash50's Avatar
a lot of work for about 2 friggin horsepower, adn the possibility it could crack and spew plastic into your motor
