Confused; header bolts - antiseize or thread locker or nothing?
Old Jan 19, 2006 | 07:58 PM
Marc '99T/A's Avatar
Question Confused; header bolts - antiseize or thread locker or nothing?
Doing a header install this weekend. I tried to search, but for some reason it isn't pulling up any information regarding antiseize or thread locker. In the past, I've seen posts where people talk about using one or the other on their header bolts. Don't they serve two opposite purposes? I'm confused; which do I go with? Or do I not put anything on them? Thanks.
Old Jan 19, 2006 | 08:02 PM
Ωmega's Avatar
Put antiseize on all header bolts. It prevents them from rust and from bonding to the block. Otherwise, after time, you'll have a lot of trouble getting them out again, especially if you use locktite, or any other kind of locking stuff.
Old Jan 19, 2006 | 08:08 PM
black01_WS6's Avatar
I would at least use antiseize on the bolts. some people use loctite if they know that is the only header they want to have on their car and want the best holding power, but it is not necessary.
Krab's Avatar
Antiseize is what I used and I haven't had trouble breaking loose the bolts when I removed my headers after 2 years. Don't use thread lock or you'll have some real trouble breaking them loose.
Old Jan 19, 2006 | 08:09 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Nothing here.
Old Jan 19, 2006 | 08:14 PM
227Hawk's Avatar
Anti-sieze and check after 1 hour. Been running headers for 3 years no leaks.
Stock gaskets with copper spray
Hawk
Old Jan 19, 2006 | 08:21 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I would always recommend anti sieze when bolting steel
into aluminum. The factory header bolts have some kind
of stuff on the threads, I'm -guessing- maybe some kind
of teflon compound. Serves both purposes. Whatever it
is, I had a bitch of a time getting it off/out of a few bolts/
holes as a couple wanted to bind up tight before being
pulled in fully.
Thanks for all the quick responses. How hard is it to get a torque wrench in there to torque them down? 18ft/lbs, right?
Old Jan 19, 2006 | 08:23 PM
Hawk
Copper spray?
Old Jan 19, 2006 | 08:25 PM
Lithium's Avatar
Some I could not get too. But just snug them up pretty good.
Old Jan 19, 2006 | 08:28 PM
Ωmega's Avatar
I don't use any torque numbers for the bolts, just as tight as I can without hurting my self...So far so good! I don't know what the copper spray is, but I just use stock replacement gaskets and Stage 8 bolts.
I'd also recommend new plugs and wires...It's just a convinient time to do them.
227Hawk's Avatar
Look in the gasket sealer section of the auto parts. Permatex copper spray a gasket.
Spray both sides of each metal stock gasket.
Hawk
Old Jan 19, 2006 | 08:29 PM
18 pounds is right and work them from the center out.
Old Jan 19, 2006 | 08:34 PM
Thanks.
Old Jan 20, 2006 | 01:35 AM
mean02Z28's Avatar
pulled in fully.
The factory bolts have threadlocker applied. GM recommends applying their own threadlocker to the threads. I have some and it is essentially red loctite.
Chris
Old Jan 20, 2006 | 10:05 AM
TheBlurLS1's Avatar
That's what she said...
Chris
I promise it's not as strong as red loctite. Have you ever used it before? Its beast.
I would NEVER use loctite on header bolts (or any other bolt that i could stand to have fall out). Would you rather remove a head to get out a snapped bolt, or reach down and tighten your exhaust?
Old Jan 20, 2006 | 04:45 PM
Kyle C's Avatar
Installed mine with anitseize about 2500 miles ago. Torqued to 18 lbs haven't retightened yet but no leaks.
