why are catch cans expensive? what about this one?
Old Jan 24, 2006 | 07:27 PM
radz282003's Avatar
I have a cheap one, like those, and it works good. I get a few tea spoons of oil in there every oil change. The baffled ones are a good idea too, but, a little expensive.
Old Jan 24, 2006 | 08:18 PM
Quickin's Avatar
So what do you do with the oil in the can, pour it back into the engine every fvew days?
Old Jan 25, 2006 | 12:26 AM
TheBlurLS1's Avatar
That's what she said...
Negative. Its not going to be a quart of oil or anything. Its going to be like, a few tablespoons. You dont even need to empty it unless there is a thread that some might actually make it to the exit hose. If you have a quart of oil in your catch can, its time for a new motor.
Remove the oil from teh catchcan and pour it into an old oil container. Most autoparts stores have a big *** tank in the back they will let you dump old oil into.
Oil going through the PCV system in excess is caused by higher crankcase pressures. This is caused by blowby, which is when your piston rings aren't sealing with the cylinder walls.
Old Jan 25, 2006 | 12:35 AM
BudH's Avatar
Here's what my $31 (shipping included) can looks like mounted! See earlier post!
Attached Thumbnails why are catch cans expensive? what about this one?-catchcan1.jpg   why are catch cans expensive? what about this one?-catchcan2.jpg   why are catch cans expensive? what about this one?-catchcan3.jpg
Old Jan 25, 2006 | 12:56 AM
konryod215's Avatar
do u see any oil in it yet?
Old Jan 25, 2006 | 09:14 AM
1CAMWNDR's Avatar
What size fittings on those 2 e-bay catch cans at the top?? I don't see any info on the fittings in the description.
OK I just saw that the top one (blue) has 1/2" fittings. What about the second one??
Old Jan 25, 2006 | 10:24 AM
BudH's Avatar
I've only driven a few miles so far and havn't opened it up to see. It won't show on the external tube until about 1/2 inch of oil accumulates.
The fittings are Metric but are very close to a 3/8 inch US. A 3/8 hose fits nicely!
Also, I removed the bottom drain fitting, tapped the hole to US NPT and installed a Drain valve. (see photo above)
Old Jan 25, 2006 | 11:05 AM
1CAMWNDR's Avatar
OK Bud. Which one did you get? One of those listed above??
Tahnks.
edit: I guess it would be the one in the link in your first post here wouldn't it .
Old Jan 25, 2006 | 02:08 PM
6spd's Avatar
ooh I'm glad you chimed in on those fittings. I was wondering about that.
These look real nice, but can't tell what the actual price is :/
http://cgi.ebay.com/ebaymotors/ws/eB...ABCA%3AUS%3A11
Old Jan 25, 2006 | 02:37 PM
1CAMWNDR's Avatar
That one is an auction. I guess try and be the last person to enter a bid.
Old Jan 25, 2006 | 04:27 PM
joecar's Avatar
Some problems with sucking oil into intake:
a. may cause knock;
b. contaminates O2 sensors and catalyst;
c. wastes oil (expensive if you use synth.).
Can plumb in a catch can, but you have to empty it regularly.
I drilled a 3/4" hole thru my oil cap, installed rubber grommet, pushed PCV into grommet, reversed flow thru PCV plastic tubes, plugged air nub near front of RHS valve cover;
when accelerating, alot of oil is pumped up pushrods into valve cover and g-force pushes it to rear of valve cover; oil cap is highest position on engine, so no liquid oil will be sucked (I peek past TB blade into manifold using flashlight, and no oil present).
I had to buy a rubber grommet.
Old Jan 25, 2006 | 05:28 PM
  #32
BigDaddyBry's Avatar
$16.50 right now ($1.50 + $15 s/h)
Old Jan 25, 2006 | 07:46 PM
  #33
6spd's Avatar
ya I bid 16 bucks and it still didn't break the reserve
joecar how long ago did you do that?
anyone else do something like Joe?
Old Jan 25, 2006 | 08:40 PM
  #34
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Originally Posted by 300bhp/ton
Unless there is excessive oil I can't see any problem with a little oil making it's way into the intake (although it is far from idea). It won't cause any real harm (to my knowledge anyhow).
Well, the problem is that oil entering the combustion
chamber contributes to knock retard, which pulls timing
and inhibits performance. It can also contribute to
deposits in the combustion chambers, and on
the piston. From what I've seen, at least in my case,
a catch can routed in line between the pcv & TB have
(so far) reduced KR.
BTW, I've had an on/off KR problem for 10s of 1000s
of miles, which I always used GM top engine cleaner to
clear up.
Best,
gwj
Old Feb 1, 2006 | 10:04 PM
  #35
Frosty's Avatar
Aside from the silver Greddy one posted has anyone used one of the red or blue ones from ebay(the links that were posted)? I'm temped to pick one up.
Old Feb 1, 2006 | 10:46 PM
  #36
LS1FIRE's Avatar
I am running a one from Ebay. Got it cheap seems to work good better then nothing. I think the other ones are way too over priced.
Old Feb 2, 2006 | 04:37 AM
  #37
300bhp/ton's Avatar
clear up.
Best,
gwj
Yeah I've heard mixed reports concerning knock and oil consumption. So if it's only a small amount of oil I still can't see it being an issue, unless the car is tuned boarder line with the grade of fuel being used.
But yes deposits I can see as being an issue, but still not major. Most engines, espcially older ones (design) all tend to burn a bit of oil in one way or another and it never harmed them at all. Even areo engines do and there's no way they would be allowed to if it wasn't safe.
Old Feb 2, 2006 | 11:14 AM
  #38
BudH's Avatar
I decided to put the catch can on after I saw the oil buildup in the exhaust ports (intake off). I also did some mods inside the can before install, since it's just an open can inside.
1. On the incoming side, I pressed a hose fitting in and dropped a hose 2/3 of the way to the bottom of the can so the vapors have to go to the bottom of the can and then back up.
2. I then made a metal platform about 2 inches from the bottom and stuffed the top 2/3 of the can with stainless steel mesh like used in the high dollar AMW can.
Time will tell how effective it will be!
Old Feb 2, 2006 | 11:17 AM
  #39
Frosty's Avatar
Cool, maybe I'll pick one up, thanks!
Old Feb 2, 2006 | 11:29 AM
  #40
LS69TA's Avatar
Originally Posted by 4thGenCamaro
What oil are you using? Try 5w40 synthetic. It should help. I run Mobil 1 5w40 in my car, and had a catch can installed for a little over 5,000 miles. When I checked the catch can, it was bone dry.
I just bought 6 qts. of 5W40 Mobil 1 last weekend. I'm probably going to change it sometime this weekend and see if it helps any.
