TD under the axle
Old Jan 21, 2006 | 08:39 PM
BDD's Avatar
BDD
Default TD under the axle
Does anyone know where I can buy a true dual exhaust system that runs under the axle for my camaro? Does anybody have some pictures of this setup on a lowered car? I wish the search would work correctly.
Thanks
Old Jan 21, 2006 | 10:54 PM
SSRZ28's Avatar
i made a post today with pics. look for it in the external section.
Old Jan 22, 2006 | 07:42 AM
99Hawk262's Avatar
I am lowered 1/2" from the factory. You'd have to have an exhast shop make a custom setup for you. Shouldn't be too much is you get your mufflers, crossover, tips and then have it all put together.
Old Jan 22, 2006 | 07:49 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Any of you guys having any sort of clearance issues with the under axle setup? Just curious. Mine goes over on both sides.
Old Jan 22, 2006 | 08:13 AM
99Hawk262's Avatar
I haven't. My lowest point are the flanges on the header collectors. They weren't turned in the most ideal position before they were welded.....but they work and they don't rub on anything. Clearance is great.
Old Jan 22, 2006 | 08:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah I guess the only way you could have a problem in the back is by hitting something parallel.
