Getting True Duals out back
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
You'll need:
2 mufflers.....Sweet Thunder, Flowmaster 1-chambers, Flo-Pro Twisters, Dynomax Bullets, Borla XR1's, etc.
If you want to model my setup, you'll need 8 flanges. four 3" and four 2.5". The four 3" go on the header collectors and the beginning of the exhaust. The four 2.5" go after the mufflers so you can drop it for jacking.
You'll need an H or X-pipe.
You'll need mandrel bends if you want to go that route and your exhaust shop doesn't have them. You'll need at least four U-shaped bends...possibly more. That all depends on how you route it.
And I would strongly recommend a 3" to 2.5" reducer. If you use that, you can subtract two of the 3" flanges. These will bolt to the flanges on the headers and then you can weld the piping to these and continue to your crossover. These provide a smooth transition from the 3" header collectors to the 2.5" piping.
If you follow all this, your list will total:
2 mufflers
2 3"-2.5" reducers
2 3" flanges
4 2.5" flanges
X or H-pipe
4+ U-shaped mandrel bends
Tips
The exhaust shop will have the hangers and everything else you need. Hope this helps.
