?'S on TB????
Old Jan 23, 2006 | 11:43 AM
BIG_MIKE2005's Avatar
Default ?'S on TB????
Ok, i just bought a P/P TB from a member on here. Its off a 02' WS6 & mine is a 99'. I have heard you have to switch out a part on them for it to work properly. Believe its called the cam?? Does anyone have a write up on this or does it even really need to be done?? Any information is very much appreciated.
Old Jan 23, 2006 | 01:54 PM
ttt...
Old Jan 23, 2006 | 07:34 PM
WILWAXU's Avatar
Throttle cam and shaft.
Old Jan 23, 2006 | 09:00 PM
yak's Avatar
yak
yeah basically, pull the tps sensors from both units. pull the blades out of both. get a hammer and pound the end of the throttle shaft a few times till it pops out. swap the shafts and rewind the spring. pop the blade back in and tada you got it all worked out. (BTW, when you pound out the shaft a little metal ring will probibly pop out, don't worry about it, you don't need it.)
Old Jan 24, 2006 | 08:18 AM
Are there any write ups with pics available??
Old Jan 24, 2006 | 02:30 PM
WILWAXU's Avatar
This might help:
http://www.geocities.com/wilwaxu/throttlebody.html
More here:
https://ls1tech.com/forums/showthrea...=139142&page=2
TB Porting 101
Ported TB pics
http://www.ls1howto.com/index.php?category=3
http://www.cardomain.com/ride/296918/6
http://www.ls1camaro.net/sections.ph...ticle&artid=16
Old Jan 24, 2006 | 02:55 PM
cyphur's Avatar
right there.....give it a little tappy tap tap tap tap..... it should come right out.
