Charging Wire Length
Old Jan 23, 2006 | 03:29 PM
BJC51984's Avatar
Default Charging Wire Length
Does anyone know how long the power wire is that goes from the alternator to the battery for charging on a 2000 camaro ss? I am gonna order a new custom alternator and it comes with a new 4 gauge charging wire and I need to let them know how long I am gonna need. Thanks.
Old Jan 23, 2006 | 04:00 PM
Dal1as's Avatar
Unfortunately I threw away the paperwork I had the measurements on when I ran new wiring myself. Your best bet is to trace the wire from your battery to the alternator using string, taping it every so often, then measure the string. You're going to have some issues hooking the side to your battery due to the way the terminal connector is wired. I kept my original wiring and just ran 4 guage along with it but had to butcher the terminal connector to do so. You'll run into the same thing.
