need help with TB assembly
Old Jan 26, 2006 | 02:36 AM
frisky2101's Avatar
Default need help with TB assembly
Okay so I just finished porting my TB and am putting it back together but I can't remember which way the ring goes on the TPS the ring is a U shape I think it goes with the top of the U facing the sensor but I'm not sure
HELP please!!
thanks
dave
Old Jan 26, 2006 | 02:53 AM
TheBlurLS1's Avatar
That's what she said...
I just happened to have an extra chillin' in my tool box
It can only go on one way, the piece in the middle of the sensor will only rotate about 90 degrees, its got an internal stop. The plug points off the front of the throttle body.
Great looking port job!
PS - Did you use loctite on the screws going into the shaft holding the blade on? Its always good to throw some good ole' blue loctite on there. It definatly wont make them fall out EASIER lol
Old Jan 26, 2006 | 02:57 AM
frisky2101's Avatar
thanks for the help and the complement
and now loctite yet, wanted to make sure sevrything went back together first
will be putting some one before I put it back in
Old Jan 26, 2006 | 03:48 AM
TheBlurLS1's Avatar
Not sure i know what you're talking about with the ring on the shaft, post up a picture of it.
Old Jan 26, 2006 | 03:55 AM
TheBlurLS1's Avatar
OHHH i think its kinda like the little bearing retainer ring sorta thing. I think the U side faces the bearing. Probably just functions as a spacer, and thus doesnt really matter which way it goes.
Old Jan 26, 2006 | 02:03 PM
frisky2101's Avatar
that's kinda what i was thinking
