How to ID an '01 LS1?
HOWEVER.. people have deleted and coverted to the newer LS6 intake manifold on older engines.. i guess you should also look for the plug to the EGR, if there is one and its not connected.. means some one swapped intakes and it was an 00,99, or 98 engine..
visually.. thats about it... other than get the Vin# from the car and see what year it is.
Heads are another good way. Look at the casting number on them. 2001 and up is 241. 00-99 is 853. 98-97 is also 853, but has perimiter valve cover bolts.
Also check the head casting #, if it isn't 241 then its not an '01/'02. But I believe '00 also got that same head casting #.
Finally the EGR as mentioned is the easiest way to tell if it was there.
