My new 100mm throttle body
Old Jan 27, 2006 | 02:51 PM
Lasershop's Avatar
Default My new 100mm throttle body
Oh.... its there. Just have to remove a little material....
Old Jan 27, 2006 | 02:52 PM
GuitsBoy's Avatar
LOL!!!
What are you going to use for the shaft and blade?
Old Jan 27, 2006 | 02:55 PM
Super Speed's Avatar
Hows the air gonna get through that? How much did that block cost and how much is the machine shop gonna charge you and finally total costs?
Old Jan 27, 2006 | 02:56 PM
Lasershop's Avatar
Originally Posted by GuitsBoy
LOL!!!
Shaft, drill rod steel. Hardened after machining. Blade solid brass.
Ill post progress soon as I get my CAD finalized.
Old Jan 27, 2006 | 03:04 PM
Quickin's Avatar
finally, someone taking it to the next level. Now I want a 105mm.
Old Jan 27, 2006 | 03:36 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Looks good. When is it going in?
Old Jan 27, 2006 | 03:47 PM
GuitsBoy's Avatar
Sounds good. What intake manifold are you gonna use?
I had often though about CNCing out an adapter or a full throttle body that has a large 90mm or so blade, but then tapes down to 78 behind the blade. The theory being that with the blade shaft not being an obstruction at the 78mm bore, it should flow much higher. Maybe you could taper the rear portion down to fit the 90mm intakes.
Old Jan 27, 2006 | 03:53 PM
777's Avatar
777
He owns his own shop. He uses lasers, hince his user name. It's also his shop name IIRC.
Old Jan 27, 2006 | 04:04 PM
GuitsBoy's Avatar
If he's gonna cut through that block with a laser!
Judging from his site, I think the laser is used more for plastics, laminates and other meltables. I have a sneaking suspicion he's got a CNC or two hiding somewhere in his shop though. Nothing wrong with milling them out the old fashioned way, but id be DAMN impressed to see a beam of light cut through 4 inches of aluminum and then stop before going right through (ie mounting flange).
Old Jan 27, 2006 | 04:07 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I want a cutting laser....sounds like i could get into some trouble with it though.
Old Jan 27, 2006 | 04:10 PM
Lasershop's Avatar
Old Bridgeport V2XT CNC. My favorite toy. Been broke down for about 8 months and I just got it fixed $$$$. Just use it for in house repairs and stuff like this. Lasers cut plastic for a living.
Old Jan 27, 2006 | 04:29 PM
WILWAXU's Avatar
Yup, there's a reason those CNC parts are so expensive.
Good luck on the project!
Old Jan 27, 2006 | 05:25 PM
NLang's Avatar
Life would be much less complicated and time consuming by just making a thin adapter to mount a 90 or 105mm Accufab 'Stang unit. They can be found polished for $200.
Of course, if your objective is simply custom/'one-off', to ya...
Old Jan 27, 2006 | 06:40 PM
6spd's Avatar
that's music to my eyes. Definately keep us posted!
Old Mar 10, 2006 | 04:34 PM
Lasershop's Avatar
Well......... I was nearly done with it. Our digital camera has seemed to walk away. Anyway.. then I started thinking. Why not, say.. 200mm. Its nearly done and probably not what you might think. Does not look like a coffee can. Stay tuned (for whoever gives a crap). Pics soon.
Old Mar 10, 2006 | 05:44 PM
NLang's Avatar
200mm? Why? lol That's beyond over-kill for even the largest ci LSx based engine available.
Old Mar 10, 2006 | 06:51 PM
Lasershop's Avatar
"beyond over-kill".......... I like it. But seriously.. 4 inline 50's. Sit atop the sheet metal manifold. Sweet.
Old Mar 10, 2006 | 09:33 PM
NLang's Avatar
Why go half-way with four units when you could just make a much more beneficial individual runner system (individual intake runner and throttle body per cylinder). It'd be even more 'sweet' looking, I might add
Old Mar 10, 2006 | 10:42 PM
Lasershop's Avatar
That's what Im talkin' about. One piece billet. Could build an individual runner but I have a different plan.
Old Mar 10, 2006 | 11:01 PM
mike c.'s Avatar
i don't see the point of this mess.
