throttle cables
Old Jan 28, 2006 | 11:42 AM
theinstag8r's Avatar
Default throttle cables
i've seen alot of z28's with the throttle cables runnig into the unit behind the battery which i think is the cruise control...the thing is my car does not have this assembly...the cables run straight under the cowl and dissapear somewhere..is anyone elses car set up this way and why is it that way
Old Jan 28, 2006 | 12:00 PM
Ωmega's Avatar
You have 2 cables right?
That box behind the battery also runs to a larger box up towards the front of the drivers side under the car. this is all part of the ASR/TCS/Cruise control system. You have crusie control, thats what the cable on the left, and the other one to the right is the throttle. You'll only have the 3 cables if you have ASR/TCS and Cruise.
Old Jan 28, 2006 | 12:35 PM
yeah i have two cables hooked to TB...and i dont have traction control..that explains why i dont have that unit then..thanks
Old Jan 28, 2006 | 12:52 PM
Coy's Avatar
Coy
If you don't have TCS, you wont have that box.
Old Jan 28, 2006 | 05:10 PM
Ωmega's Avatar
Yea, It looks a lot cleaner with out the three cables running every which way. I just tore all that crap out, I now only have 1 cable, straight from the pedal to the throttle body.
