What EXACTLY do I need?
Old Feb 1, 2006 | 01:22 AM
Shamson5.7's Avatar
Default What EXACTLY do I need?
Looking to get some Pacesetters very soon. My uncle said he could build me a Ypipe (he has an exhaust shop) so other than that Im looking for what I need to purchase.
What all do I need to get? O2s? AIR? EGR? Im a noob when it comes to exhaust systems, could definately use some help here fellas.
Old Feb 1, 2006 | 01:32 AM
NoGamesLS1's Avatar
You'll need o2 extenders and o2 sims. You should do true duals, not a y pipe. It may cost more but it will be worth it.
Old Feb 1, 2006 | 01:37 AM
Shamson5.7's Avatar
I may convert sometime down the road, but right now Im on a very tight budget. Headers will be the last thing I do to the car for the remainder of the year.
What type of tuning will I need? and How much do O2s usually run?
Old Feb 1, 2006 | 04:52 AM
JMBLOWNWS6's Avatar
Pacsetters with a hooker ORY fit perfect. Clears the floorboard of the car no problem. You have a choice. Either extend the wires off the cars harness or buy extensions. The rear 02 simms will be needed if you dont want an annoying SES light. Or you can take it to someone who has edit,efilive or hp tuners to turn off the codes. I usually charge about $50 to do that.
Old Feb 1, 2006 | 07:35 AM
Ling_650vette's Avatar
Unless your state is tight about emissions, you wont need the AIR or EGR system(s) either, especially if you're getting an Offroad Y/X pipe. If you're getting one with cats, you can keep both systems, delete one system or both systems. Depending upon who you talk too, you'll get a different philosophy on what to keep and what to trash.
Old Feb 1, 2006 | 03:31 PM
Shamson5.7's Avatar
So basically if I know someone who has edit, all that I really need to get then are the headers? What does deleting AIR and EGR accomplish?
Old Feb 1, 2006 | 03:39 PM
NBM2001z28's Avatar
Restricted User
More room in the engine bay and a little less weight. Other then that, basically nothing. EGR doesnt function under full throttle so that isnt robbing any power.
WHere are you located at too? If you're around illinois, we can delete codes for you and provide you with the headers. PM Me if you need anything...
Old Feb 1, 2006 | 04:41 PM
Shamson5.7's Avatar
Im near Denver, CO. The guy who sold me the car has LSedit for my VIN so I just need to know what needs to be done with that program to make the headers function with my car.
Old Feb 1, 2006 | 04:45 PM
carado1984's Avatar
deleting air and egr lets you run race style pacesetters which flow better because nothing is obstructing the flow, such as the air and egr tubes... so just have them deleted and get the race style, i think theyre cheaper too..
Old Feb 1, 2006 | 04:50 PM
JMBLOWNWS6's Avatar
Yup. So your in luck. You have the software to delete codes and get rid of the emissions crap
Old Feb 1, 2006 | 07:16 PM
Shamson5.7's Avatar
Will the car be driveable if I delete the AIR/EGR w.o a tune? I may have to put off the tune for a week or so.
Old Feb 1, 2006 | 07:34 PM
Firehawk853's Avatar
Yes, it will cause the SES to come on but it won't effect drivability. You'll be fine until someone adjusts the codes for you.
Old Feb 1, 2006 | 07:41 PM
akZ28's Avatar
If your uncle has an exhaust shop get him to build you a true dual setup.
Old Feb 1, 2006 | 08:11 PM
freakynipples69's Avatar
I'm telling you right now, your car will run like dog **** after the install. Your A/F ratio will be all out of wack. If you can't afford a full dynotune(or looking to do a cam in the near future) buy a Mass Air Flow Translator(MAFT). It will rich/lean out your A/F ratio.
Just think of it as a band-aid for now.
Old Feb 1, 2006 | 08:54 PM
carado1984's Avatar
borrow someones car for a week, you cant or should i say, should not drive it with the front o2 sensors not hooked up if they havent been deleted..
Old Feb 1, 2006 | 09:54 PM
Shamson5.7's Avatar
Problem is is that I dont want it to be extremely loud. The car is also lowered so I may have clearance issues, also dont care for the no exhaust tip look. And again...Im on kind of a budget here. Im tryin to get a header install done before March. True Duals can always come later.
Deleting the EGR andAIR sounds like a major pain in the *** it seems. Will my car still run like crap if I keep those?
Cant afford a dynotune for the time being, but LSedit is at my disposal ...kinda. What do I need to mess around with in edit to get my car running right with/without EGR/AIR
Old Feb 2, 2006 | 12:41 PM
Shamson5.7's Avatar
Ttt...
