Best TB for a stroker.
Old Feb 2, 2006 | 10:31 AM
V-seriesTech's Avatar
Default Best TB for a stroker.
Just did a Shafiroff 383 AFR 225 and magnacharged V series. The blower is killing it, so we are removeing it.
Now going to FAST 90mm and was gonna go with a LS2 90mm. Will that be sufficent, or is there a LARGER TB available?....Of should I use a TPiS?
I think the LS2 unit should be fine but,...wanted to see if anyone has had experience with this.
Thanks,
J
Old Feb 2, 2006 | 10:47 AM
300bhp/ton's Avatar
I've not heard of an off the shelf item bigger than 90mm, but there was a thread only week about someone making their own 100mm TB (they have all the CNC gear to do it).
FAST 90 or NW 90 seem popular but I can't see any reason why a ported LS2 won't do.
Old Feb 2, 2006 | 10:53 AM
FAST 90 or NW 90 seem popular but I can't see any reason why a ported LS2 won't do.[/QUOTE]
Cool, thats what I thought too,... I can probably get it brand new dirt cheap as wel,..so, I think we'll end up going withthat.
thanks.
J
Old Feb 2, 2006 | 04:31 PM
300bhp/ton's Avatar
The only thing you'd better check is if the LS2 TB will has the same bolt pattern as the FAST intake. I have no idea if it does or not but I vagly remember something about it and other TB setups.
Old Feb 2, 2006 | 04:41 PM
carado1984's Avatar
do the nick williams 90mm.. ls1speed has it... its better than stock ls2 or the fast 90.. and also cheap than the fast
Old Feb 2, 2006 | 04:47 PM
They ALL should be the same EXACT bolt pattern
....and I can get it for $290 bucks....
So I have to ask...How much better IS the fast/tpis/nick williams then the stock LS2?
Old Feb 2, 2006 | 05:08 PM
wildta's Avatar
Just wondering why the blower is killing it ? I know Cartek has a 383 magnacharger and also EastCoastSupercharging has doene a 383 magnacharger.
Is it the cam? head cc ?, or Pulley size ?
Warren
