High Flow Cats - which ones?
They are going to be available shortly...
Marketing pictures are on the way.
Prices are very competitive AND there will be a California Certification EO in the works.
These are ONE piece (no welded caps) and have flow characteritics specifically designed to optimize each inlet/outlet diameter.
These will be offered in 2.5 / 3.0 / 3.5 inlets/outlets AND in 30* offsets with altered centerlines. All bodies are 4" in OD with seamless stainless steel contruction.You want more tight fitment ooption we will be offering the most. Pictures will explain these shaped options much better...
Stay tuned
The parts we have sold were always ceramic and were intended to be High Flow AND Compliant parts. These parts WILL pass an emissions sniffer test and in most applications (some LT Header designs excluded) will not trigger PO420/430 codes. The fact that they flowed extreemly well was simply a plus.
We never really intendeed these to satisfy racers or the big performance enthusiasts but for the price and their performace they are tough to beat. You have probably seen this Dave Vizard test a thousand times but...
Inlet Diameter (in.) Outlet Diameter (in.) CFM @ 20.4” H2O CFM @ 28” H2O
OEM Passenger Side Catalytic Converter
2.5 - 2.5 - 299.5 - 350.9
OEM Driver's Side Catalytic Converter
2.5 - 2.5 - 268.3 - 314.4
TTS Bullet Catalytic Converter
2.5 - 2.5 - 277.1 - 324.6
Carsound Catalytic Converter
2.5 - 2.5 - 372.7 - 436.7
FLP Catalytic Converter
2.5 - 2.5 - 376.0 - 440.5
NOW the new metallic parts are designed around maximum flow AND still meeting tough emissions standards. These cats are CARB CERTIFIED FOR CALIFORNIA USE upto 4.0L.
When we attempt to design a new product we do so with specific intension to deliver the best part at the best price... and i can tell you that our cat will NOT exceed $200 each and will see a more fair market price between $150-180 all things considered. Nerly $500 for two universal converters is price gouging....
This is a chart of how well each of the major high-flow cats compare. The figures you see are in cubic feet per minute, which is a measure of how much air the cat will allow through per minute. The higher the number, the better. Catalytic converter flow rates at 1.5 inches of mercury.
Random Tech #616806 434 cfm
Car Sound #93009 428 cfm
Car Sound #94009 417 cfm
Walker #15147 391 cfm
Random Tech #616549 355 cfm
Stock LS1 304 cfm
MAC LS1 293 cfm
Stock LS1 304 cfm
MAC LS1 293 cfm
