Top breathing manifold needed
Old Feb 5, 2006 | 09:06 PM
wadd's Avatar
Default Top breathing manifold needed
I'm looking to build a top breathing LS engine, so it's either 8 intake stacks, or a single plane manifold with a throttle body on top. Anyone have experience with any intake/EFI systems that work nicely and aren't a huge pain to install? Ive seen something called a Mass-Flo efi system that uses, you guessed it, mass flow instead of SD tuning. But it seems like everybody using a hot LS motor turns off the MF and uses SD tuning.
Any suggestions for systems I should look at?
