Installed O2 simms and car is running rough-
Old Feb 6, 2006 | 06:59 PM
2000droptz's Avatar
Default Installed O2 simms and car is running rough-
Why is my car running so rough after I installed my O2 simms, maybe I put them in the wrong place, but I dont see how thats possible considering there is only one place for them to go. What is going on?
GR33N GoblinM6's Avatar
you're supposed to put them in place of the REAR 02's only... check to make sure you have them in the rear.
Old Feb 6, 2006 | 07:08 PM
2000droptz's Avatar
Well, just to make sure, where are the rear O2's located? Because I am pretty sure that is where I plugged them into.
Old Feb 6, 2006 | 07:28 PM
2000droptz's Avatar
I need some help here asap.
Old Feb 6, 2006 | 07:49 PM
theinstag8r's Avatar
there are 4 o2 sensors on your car ...it's hard to mistake the rear two from the front two...one sim should plug into the harness located on the drivers side above the tranny linkage if you have an a4...the other one is on the other side about a 1-2 feet up towards the front of the vehicle...this might not help you much but it's a small reference
Old Feb 6, 2006 | 10:38 PM
spanker's Avatar
the ones after the cat converter towards the rear of the car
Old Feb 6, 2006 | 10:47 PM
MikeG's Avatar
I never had any luck w/ o2 sims. I wound up just getting the car tuned and all my problems were solved.
