LS6 manifold or LT's + ORY??
Old Feb 14, 2006 | 01:11 AM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by SSmokin99
Yeah well I decided to go with the catted Y. I talked to my cousin that smogs cars and he said I'm better off going with the LT's and catted Y because he said it would be to f*ckin hard to pass. I have a question about the EGR...will I have the EGR when I get the LS6 manifold, Lt's + ORY??? Why doesn't the 01/02 LS1's have EGR???
Nice choice on the catted y, it will provide a much more refined tone.
90% of LS6 intake manifolds do not have the provision (hole) for EGR, as they are mostly just taken off of some 01+ car. SLP sells an LS6 intake manifold WITH the hole, if you want to keep all your crap (california). My suggestion would be go and have all the emissions codes deleted so you don't have to run O2 sims in place of the rear O2 sensors. You will also be able to remove the EGR and AIR systems. I would go with the "race" version of the headers, as they have no provisions for EGR/AIR and would not make it obvious when someone looks under the hood and sees block off plates. Not that this would really matter i they look under the car and see 3" collectors
The 01+ cars don't have EGR because they use a slightly smaller camshaft with a bigger LSA, and diddn't need it per emissions requirements. It is the same camshaft used in the 6.0l truck motors from the time.
Old Feb 14, 2006 | 01:21 PM
98Z28MASS's Avatar
yea id def stick with the catted y as i didnt even see you were in cali so unless you know a garage owner that will pass you id be careful.
Old Feb 14, 2006 | 08:35 PM
ChaseSS's Avatar
headers b/c you get more power, awesome sound, and don't need a tune
Old Feb 17, 2006 | 08:13 PM
SSmokin99's Avatar
So should I get the LS6 intake with the hole? If I got with LT's i'm going to be illegal anyway. Where could I go to have all the emissions codes deleted? If I get a catted Y will I need o2 sims?
Old Feb 17, 2006 | 09:22 PM
SSmokin99's Avatar
ANyone?
Old Feb 18, 2006 | 01:43 AM
TheBlurLS1's Avatar
Get the LS6 intake without the hole and no NOT buy O2 sims. If you do this, you can buy the "race" headers and have a much cleaner engine bay. The cats in the y-pipe are going to give the rear O2 sensors a reading that is probably going to trigger the SES light, and i dont even think they have bungs welded in for that.
Search for some sponsers that are close to you and have ls1edit/hp tuners. They can delete the codes for AIR/EGR/rear O2's for usually less than the cost of O2 sensors alone!
I think Speed Engineering is in CA somewhere...
If you click alpha sponsor list at the top, you can enter your zipcode and find places close to you. OR you could ship your PCM somewhere and have it done if you don't live by anybody.
I'm not sure if you can do it or not in CA, but before you go and mod, get the car inspected so you'll be good for at least another year
Old Feb 18, 2006 | 11:48 AM
SSmokin99's Avatar
Alright thanks
Old Feb 18, 2006 | 01:58 PM
SSmokin99's Avatar
I read on this site a few weeks ago that you have to install one header at a time...Is this true?
Old Feb 18, 2006 | 02:08 PM
john5632's Avatar
Ive got lt ory loudmouth no tune runs fine wish Igot the cats though cuz with the loudmouth,well lets say its loud! I might put in a hooker muffler see if that helps tone itdown abit.
Old Feb 18, 2006 | 02:10 PM
john5632's Avatar
as fsr as the gas smell, only the mustangs in the back of my car smell it.
Old Feb 18, 2006 | 09:04 PM
SSmokin99's Avatar
So if I got LT's(racing) + catted Y will it directly bolt on as of the mods I have now or will I have to get the LS6 manifold without the hole? I don't quite understand.
Old Feb 28, 2006 | 06:27 AM
  #32
LoSTRaMaiR's Avatar
so, get race style LT's, catted Y, no 02 sims, no 02 extensions? that is what you would need if you intend to tune out the codes? how long could you run with LTs and y installed with no tune (if you don't do egr/02 sims and such)?
