Does anyone have the part number for a water pump?
Old Feb 13, 2006 | 11:18 PM
2000 Tran Zam's Avatar
Default Does anyone have the part number for a water pump?
stock oem water pump for a 2000 ls1?
i searched in gm parts direct and found this : 12458934
however when i go to add it to the cart it didnt work.
can anyone help out?
Thanks.
Old Feb 13, 2006 | 11:28 PM
ACW's Avatar
ACW
Thanks.
Well, it used to be
LS1/LS6 water pump (98-02) (AC-Delco #252-781) = 12458934
I thought I had found the updated number to be 89017456 (AC-Delco #251-690), but on looking that up, it says it's only used for the LS2 GTOs, and 12458934 is still supposed to be used for LS1s!
You could just do a Google search for the old number and buy it from the company still selling it under that number, which comes up towards the bottom of the first page of results.
Old Feb 14, 2006 | 01:33 AM
Do I have to get one from GM, or can I use one from autozone?
Which was is better?
Old Feb 14, 2006 | 08:16 AM
2001NBMZ28's Avatar
I looked it up at Pace and it says the new PN is 89017593, works at gmpdir too.
Old Feb 14, 2006 | 11:33 PM
ACW's Avatar
ACW
Interesting, that part number maps back to the same AC-Delco #251-690 too. However, Pace finally confirms that it is the new one for LS1/LS6 in addition to being for LS2!
Old Feb 15, 2006 | 01:27 AM
slowpoke96z28's Avatar
a gm one will be better a little, but the autozone one will/should be fine. normally gm stuff is new, and the parts store stuff is normally reman stuff.
Old Feb 15, 2006 | 08:26 PM
WILWAXU's Avatar
Why not try SDPC >>--->
